Lucky[BG]
Как да задам след кликане върху банер да се отваря линк?
Здравейте, търся помощ?
Направих си банер (SWF) и искам след като се кликне с мишка върху него да се отваря даден линк?
Какво трябва да задам и къде?
Ето линк към HTML кода, който генерира програмата с която създавам банера (proba.swf):
<center> <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,22,0" id="proba" width="205" height="77" > <param name="movie" value="proba.swf"> <param name="bgcolor" value="#FFFFFF"> <param name="quality" value="high"> <param name="allowscriptaccess" value="samedomain"> <embed type="application/x-shockwave-flash" pluginspage="http://www.adobe.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash" name="proba" width="205" height="77" src="proba.swf" bgcolor="#FFFFFF" quality="high" allowscriptaccess="samedomain" > </embed> </object> </center> </div>
  <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html lang="en"> <head> <base href="http://www.coothead.co.uk/images/"> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"> <meta name="language" content="english"> <meta http-equiv="Content-Style-Type" content="text/css"> <title>making flash object into a link</title> <style type="text/css"> body { background-color:#000; } #flash-holder { position:relative; width:240px; height:160px; border:3px double #f00; margin:auto; } #flash-holder { display:block; } #flash-holder a { position:absolute; width:240px; height:160px; left:0; top:0; background-color:#fff; opacity:0; filter:alpha(opacity=0); } </style> </head> <body> <div id="flash-holder"> <object type="application/x-shockwave-flash" data="radiate.swf" height="160" width="240"> <param name="movie" value="radiate.swf"> <param name="wmode" value="transparent"> </object> <a href="http://www.htmlforums.com/flash-development/t-how-to-add-link-to-swf-file-please-help-142567.html"></a> </div> </body> </html>
Ако направиш така със CSS--ориентираш ли се
Благодаря, за съвета. Чак сега ми остана време да тествам твоето предложение.
Всичко се получи, както си описал. Нагодих кода към моя случай и на компа ми се зарежда нормално всичко, НО като кача файловете на сървъра и банера не се вижда, а се вижда само фона под него и линка, към който сочи?
Каква е причината, на компа ми да се вижда всичко наред, а в нет-а банера не се вижда, а се вижда само фона под него?
Проблема е в в първият банер под "РЕКЛАМА"
сайта
П.С. Извинявам се, че давам линк към сайта, но така май ще се открие по-лесно проблема. Моля, Помагайте.
Вътре над <a href=" " target="_blank"></a> сложи :
<embed src="stavaliveshop.swf" width="205" height="100">
Нещо не се получава. След тези корекции, се появява бял правоъгълник на мястото на банера (вместо фон-а, преди тези корекции) и не сработва коректно линка, ами в десния горен край на този правоъгълник се появяа ръчичката за клик?
Нещо друго да пробвам?
П.С. Като кликна с десен бутон върху банера, ми дава съобщение: "Movie not loaded ..."
Това защо ли е така?
Ако бачка локално -трябва да бачка и на сървъра!
Не трябваше всичко да го слагаш във embed
Да не си го качил флаша във някоя папка вътре
Ако хората имат флаш си тръгва само със embed-http://www.w3schools.com/tags/tryit.asp?filename=tryhtml5_embed
Както на горния пример му бачка линка на човека!
Ако искаш да мина до адреса ?
Не виждам да си го направил както ти казах!
От варна съм -ако искаш да мина на адреса от сайта утре 30.10 2013 и да го оправим !
За да не се налага да ми даваш пароли на хостинга!
Пробвах и това, което ти предложи, ето сега дори е точно както си написал, но пак не се получава.
Ще се радвам да решим проблема и ако не те затруднява заповядай на място.
Адреса е от сайта: ул. Битоля №4, партер, Копирен център Кадко. (това е срещу Пикадили център)
Търси Пламен.
П.С. Работното време е както пише в сайта: от 8:00 до 18:30 ч.
Искам да изкажа големи благодарности на IN-VISIBLE, за помощта и съдействието, което оказа за откриване и решаване на проблема.
Много коректен и точен. Препоръчвам го на всички, които търсят и имат нужда от помощ или съвет.
Моят проблем се реши за минути, а толкова време се мъчих да го открия - оказа се едно "дребно" датайлче :), - името на банера беше изписано с главна буква, така беше качен на хоста и това явно бъркаше зареждането му коректно в браузърите. Направих името с малки букви, както е изписано в HTML кода и всичко "заспа".
Още веднъж благодарности на IN-VISIBLE за помощта.
П.С. Към модераторите - вече може да заключвате темата.
