Проблем с инсталиране и стартиране на Webmin на Deepin 20, Debian Buster базиран !
backinblack
 Сподели
На вече стария Deepin 15, който е Дебиан 9 Стреч базиран си работи, но на новия се инсталира уж коректно, като му спра апп стора, но не стартира :( !
Last login: Wed Oct 28 11:05:52 2020 from 192.168.1.20
[email protected]:~# service webmin stop
[email protected]:~# service webmin start
Job for webmin.service failed because the control process exited with error code.
See "systemctl status webmin.service" and "journalctl -xe" for details.
[email protected]:~# systemctl status webmin.service
● webmin.service - LSB: web-based administration interface for Unix systems
   Loaded: loaded (/etc/init.d/webmin; generated)
   Active: failed (Result: exit-code) since Wed 2020-10-28 11:18:47 EET; 40s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 12719 ExecStart=/etc/init.d/webmin start (code=exited, status=139)
окт 28 11:18:47 User-PC systemd[1]: Starting LSB: web-based administration interface for Unix systems...
окт 28 11:18:47 User-PC perl[12720]: pam_deepin_authentication(webmin:auth): Cannot get original tty attributes: Inappropriate ioctl for device
окт 28 11:18:47 User-PC perl[12720]: pam_deepin_authentication(webmin:auth): Password
окт 28 11:18:47 User-PC perl[12720]: pam_deepin_authentication(webmin:auth): Password:
окт 28 11:18:47 User-PC systemd[1]: webmin.service: Control process exited, code=exited, status=139/n/a
окт 28 11:18:47 User-PC systemd[1]: webmin.service: Failed with result 'exit-code'.
окт 28 11:18:47 User-PC systemd[1]: Failed to start LSB: web-based administration interface for Unix systems.
[email protected]:~# journalctl -xe
-- Стартирането на модул „deepin-elf-verify.service“ завърши.
-- Резултатът е: done
окт 28 11:20:06 User-PC deepin-elf-verify[12861]: [ERROR] failed to open: No such file or directory
окт 28 11:20:06 User-PC systemd[1]: deepin-elf-verify.service: Main process exited, code=exited, status=255/EXCEPTION
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- An ExecStart= process belonging to unit deepin-elf-verify.service has exited.
-- The process' exit code is 'exited' and its exit status is 255.
окт 28 11:20:06 User-PC systemd[1]: deepin-elf-verify.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit deepin-elf-verify.service has entered the 'failed' state with result 'exit-code'.
окт 28 11:20:06 User-PC deepin-deepinid-daemon[3939]: [WAR] manager.go:216: skip doSync
окт 28 11:20:09 User-PC systemd[1]: deepin-elf-verify.service: Service RestartSec=3s expired, scheduling restart.
окт 28 11:20:09 User-PC systemd[1]: deepin-elf-verify.service: Scheduled restart job, restart counter is at 344.
-- Subject: Automatic restarting of a unit has been scheduled
-- Automatic restarting of the unit deepin-elf-verify.service has been scheduled, as the result for
-- the configured Restart= setting for the unit.
окт 28 11:20:09 User-PC systemd[1]: Stopped deepin ELF Verify.
-- Subject: Модул „deepin-elf-verify.service“ вече е спрян
-- Спирането на модул „deepin-elf-verify.service“ завърши.
окт 28 11:20:09 User-PC systemd[1]: Started deepin ELF Verify.
-- Subject: Модул „deepin-elf-verify.service“ вече е стартиран
окт 28 11:20:09 User-PC deepin-elf-verify[12862]: [ERROR] failed to open: No such file or directory
окт 28 11:20:09 User-PC systemd[1]: deepin-elf-verify.service: Main process exited, code=exited, status=255/EXCEPTION
окт 28 11:20:09 User-PC systemd[1]: deepin-elf-verify.service: Failed with result 'exit-code'.
lines 4863-4918/4918 (END)
Нищо не им разбирам на тези неща :( , ама без него съм с вързани ръце :( !
Линк към коментара
backinblack, би трябвало и на теб да е направило впечатление, че на тоя Deepin много неща не вървят. Още не съм разбрал, какво толкова ти харесва и толкова държиш на него?
Интересно защо точно с тая китайска дистрибуция правиш група, за да я побългаряваш?
Линк към коментара
преди 1 час, vpvelev написа:
Колкото и да ти е чудно, точно с нея има най-малко проблеми за такива нови юзверги, дето досега до Линукс не са се докосвали от една страна, а от друга страна, доста по-съвместима е с Уиндоус от колкото с другите, а нещата, за които аз лично се интересувам са такива, дето обикновен потребител не го интересуват.  Това е само от една страна, а от друга страна, в други постове споменах, че имам и друга инициатива, която е за такива, които искат не само да ползват, а и да творят и точно тази дистрибуция има много голям стор за приложения, дето няма условия под какъв лиценз ще бъде.
Целта ми е да влезе в бизнеса, а за бизнеса е много важно, ама от първостепенна важност да не се налага да влагат и в обучение на работници. Затова и съвместимостта с Уиндоус е на първо място.
Линк към коментара
И аз никаква идея нямам - явно се оплаква, заради някакви промени по PAM , които са правили от deepin
Линк към коментара
Мамка му, точно заради липсата на Уебмин търся разни други програми, с които да се настройват графично разни неща :( ! С него и паролата на root юзера се сменя и нови юзери с външен достъп се създават и бекъп на бази.... ! То друго не му трябва на ПОТРЕБИТЕЛЯ . Инак тва с терминала е крива работа :( .
преди 20 минути, borovaka написа:
Сега се замислям, че може и да не е в PAM-а, щото съм го пробвал и с добавени дебиански хранилища. Получава около 100+ ъпдейта, но и пак не тръгва. Ако са правили някакви корекции, все си мисля, че пакета от дебиан ще замени техния :( .
Линк към коментара
backinblack, трябва да качвам Deepin, за да помагам.
Пробвай да го стартираш така да видим какво ще се получи при теб.
Нямам сървър да пробвам, но на локалето работи:
Линк към коментара
преди 24 минути, vpvelev написа:
Братле, в момента съм върнал снапшота до преди да го инсталирам, но мога да го инсталирам отново за нула време и да ти пусна достъп по SSH от рутера, но съм на статично динамично ИП и само да не се смени, докато влезеш :( .
Абе, дайте една команда за мариядб, дето да създава нов юзер с пълни права като роот, но да има достъп от вън, демек от всички хостове! Мъча се тука по разни инструкции, ама не ми се получава :( ! Създавам го само за локалхост правилно, ама за ани хост не ми се връзва програмата, а през уебмина няма проблем като го направя.
Линк към коментара
преди 27 минути, backinblack написа:
Пробва ли това?
sudo usermod -aG root,http <user name>
Линк към коментара
преди 53 минути, vpvelev написа:
Пробва ли това?
С командата: mysqladmin --user=root password "11111" задавам парола 1111 на роот юзверга :) ! После, с командата  mysql -u root -p влизам, като ми иска парола и попълвам 1111 . Като вляза, изпълнявам командата: GRANT ALL PRIVILEGES ON *.* TO 'user'@localhost IDENTIFIED BY '11111';  и ми се създава юзверга user, ама само с достъп от вътре по локалхоста. Пробвах с 'user'@any щото така ми го изобразява уебмина, ама не става :( ! С какви символи да заменя това @localhost !!!? Ей тука ми е проблема!
Линк към коментара
преди 7 минути, backinblack написа:
Може би с това?
GRANT ALL PRIVILEGES ON *.* TO 'user'@'%';
Линк към коментара
 GRANT ALL PRIVILEGES ON *.* TO 'user'@"%" IDENTIFIED BY '11111';
Deepin си е типичен китайски боклук
преди 6 минути, vpvelev написа:
Може би с това?
Ей изпревари ме с тоя забил форум
Линк към коментара
Мамка му, сичко живо проценти иска :D ! С 'user'@"%" се получи :D ! Благодарско :) ! На времето, когато почнах да ползвам Линукс с Убунту 10.04, ако още в началото не ме бяха светнали от линукс форума за наличието на този инструмент Уебмин, сигурно още след първата седмица щях да се откажа от Линукс :(  . Терминал ползвам само и единствено, когато изпълнявам инструкции от нета, дето идея си нямам какво и защо правя :) .
Линк към коментара
преди 10 минути, backinblack написа:
Това дето ти го дадохме е SQL заявка за права :) Ако толкова ти е зор за заявките ползвай DBveawer ама иска да имаш OpenJDK 11
Линк към коментара
преди 2 минути, petie1 написа:
Абе, то DBeaver се пробвах да го пробвам, ама там у апсторето има само профешъна, дето иска кинти, а другото, комюнитито го инсталирах, ама не ми стартира :( .
Линк към коментара
преди 19 минути, backinblack написа:
Сега прочети хубаво какво съм написал "...ама иска OpenJDK 11" :)
Линк към коментара
Разгадах го
Първо с
sudo apt-cache search deepin-elf-verify
намираме deepin elf verify
инсталираме го
sudo apt-get install deepin-elf-verify
И тогава вече Уебмина би трябвало да запали
Линк към коментара
преди 9 часа, petie1 написа:
Разгадах го
Първо с
инсталираме го
Братле, не ми се получава :( !
# Webmin
apt-get install build-essential gcc libc6-dev libwrap0 libwrap0-dev libwww-perl apt-transport-https wget
cat >> /etc/apt/sources.list.d/webmin.list <<-EOF
deb http://download.webmin.com/download/repository sarge contrib
deb http://webmin.mirror.somersettechsolutions.co.uk/repository sarge contrib
EOF
2) wget http://www.webmin.com/jcameron-key.asc && apt-key add jcameron-key.asc && apt-get update && apt-get install webmin -y
4) cpan Authen::Libwrap
service webmin stop  service webmin start  service webmin restart
Това е инструкцията по която го инсталирам през SSH логнат като root. По-долу са скрииншоти на протеклата инсталация и не ми стартира :( .
Това е втора инсталация с твоите инструкции. След първото несполучливо стартиране, предположих, че заради мен си направил чиста инсталация и се върнах на снапшот чист инстал след първи ъпдейт. Без нищо да съм магерил по него. Пробвах нов инстал на Уебмин и това по-горе е резултата! Щом си го стартирал явно си го разгадал и при мен нещо се бърка работата. Моля те, дай ми точна последователност на командите, че с те терминали ми куца работа :( . Горе-долу разбирам разните инструкции какво вършат и как да си ги променя за себе си да ми е по-лесно, но до тук съм с терминала.
Линк към коментара
Не виждам да си изпълнил:
както ти е написал Petie1.
Също така не виждам да си изпълнил някъде 4та точка от плана за инсталация:
Можеш ли да пратиш линк от страницата от която инсталираш?
Линк към коментара
преди 12 минути, caball написа:
Изпълнил съм го точно по неговата инструкция след инсталирането на Уебмин! Сега се сещам, че може би е имал в предвид, че трябва да се инсталира този пакет преди инсталацията на Уебмин. На втората снимка се виждат командите и резултата след тях. В края на скрииншота са.
преди 15 минути, caball написа:
Този перл модул не е задължителен и той се ползва само за някакви. Инсталирам го него само колкото да не ми показва, че имало липсващи модули.
Тази инструкция си е моя преработена от друга и с по нея съм инсталирал над 100 пъти безпроблемно на Убунту и Дебиан.
Линк към коментара
За съжаление не успях да го подкарам :( Изглежда Боровака е прав и трябва да се нагласи РАМ-а
Линк към коментара
За сега спирам да се занимавам с 20 и се връщам на 15, но въпроса си остава актуален :( . Снощи прехвърлих нещата на жИлязо и се оказа, че не му достига видеото :( . Като за начало, трябва да върви на машинки с минимум сокет 755 с графика Graphics Media Accelerator 3100 нагоре, но на такова жилязце изобщо не запали. Изгрява тапета и преди да излезе прозореца за логване се рестартира. На малко по-добрите Intel Q45 Express with Intel GMA 4500 Graphics си пали и върви, ама като стартирам хрома и почва да скляпа :( !
Тези машинки с 2 ядра Е8300+, 4ГБ рам и 128ГБ SSD са перфектни за офис работа. Работят достатъчно бързо сериозна работа и са под 100 лева + 50 лева инвестиция в SSD, като при проблем с желязото за нула време диска се прехвърля в друг компютър за същите пари и работата не спира.
С по-старото 15.11, което е базирано на все още актуалния Дебиан Стреч нямаше такива проблеми, като го качвах на желязо.
Както и в другия пост писах, целта ми е да привлека бизнес потребителите да започнат поне малко от малко да ползват Линукс.
Линк към коментара
Аз успях да го подкарам като спрях модула Deepin authentication ( само горният, не знам защо са дадени два , може и да е бъг, защото само по малка/главна буква се различават) :
Това го извикваш с командата:
 pam-auth-update --force
След това тръгва, друг е въпроса до колко добре и сигурно ще работи :) Тази диструбуция не е в списъка на поддържаните от webmin така че май няма много много гаранции като цяло.
PC:~# systemctl status webmin.service
   Active: active (running) since Tue 2020-11-03 18:08:38 EET; 6min ago
  Process: 8947 ExecStart=/etc/init.d/webmin start (code=exited, status=0/SUCCESS)
    Tasks: 3 (limit: 4108)
   Memory: 31.7M
   CGroup: /system.slice/webmin.service
           ├─8998 /usr/bin/perl /usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf
           ├─9186 /usr/bin/perl /usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf
           └─9189 /usr/bin/perl /usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf
Nov 03 18:08:36 peio-PC systemd[1]: Starting LSB: web-based administration interface for Unix systems...
Nov 03 18:08:36 peio-PC perl[8948]: pam_unix(webmin:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost=  user=root
Nov 03 18:08:38 peio-PC webmin[8948]: Webmin starting
Nov 03 18:08:38 peio-PC systemd[1]: Started LSB: web-based administration interface for Unix systems.
Линк към коментара
Благодаря Френд :) ! Ще го тествам, но в старата версия 15.11, която е базирана на Дебиан 9 Стреч, Уебмин си го познава, че е Дебиан Стреч и няма проблем, а на Deepin се инсталира и работи. Проблема е с 20-та версия, която е с почти нов десктоп менажер, който си е малко суров още и е базирана на Дебиан 10, но с клонирани дебиански хранилища, защото в техните май има пакети и от сид и от нестабилните. Но без проблем се добавят дебианските хранилища и си работи, като се обновяват и доста пакети, които те не са ги обновили. Вариант е след инсталацията да се ползват основно дебианските хранилища, а тяхното да е като допълнително.
Явно поради несъгласие с идеологията на Дебиан се отделят както Убунту на времето проходи. Следват точно неговите стъпки, но пък и Минт се отделя в свои си хранилища, които все още са базирани на Убунту. Вече изисква, като добавяш ново хранилище да отговаря на версията на Минт, а не на версията на Убунту, върху която е базиран :( !
Линк към коментара
 Сподели
