Проблем при сваляне на клипове от GoPro камера на копютъра
Здравейте колеги  :bye1: като тръгнем да свалям клип от камерата на компютъра започне да се копира и зацепи тотално а и някои път изпише "this operation returned because the timeout period expired"
съдържанието на файла FRST.txt :
Scan result of Farbar Recovery Scan Tool (FRST) (x86) Version: 25-12-2014
Ran by USER (administrator) on PC on 25-12-2014 21:05:39
Running from C:\Documents and Settings\USER\My Documents\Downloads
Loaded Profile: USER (Available profiles: USER)
Platform: Microsoft Windows XP Professional Service Pack 2 (X86) OS Language: English (United States)
Internet Explorer Version 6
Boot Mode: Normal
==================== Processes (Whitelisted) =================
(If an entry is included in the fixlist, the process will be closed. The file will not be moved.)
(NVIDIA Corporation) C:\WINDOWS\system32\nvsvc32.exe
(Realtek Semiconductor Corp.) C:\WINDOWS\RTHDCPL.EXE
(Microsoft Corporation) C:\WINDOWS\system32\rundll32.exe
(Sun Microsystems, Inc.) C:\Program Files\Common Files\Java\Java Update\jusched.exe
(Logitech Inc.) C:\Program Files\Logitech\Gaming Software\LWEMon.exe
() C:\Program Files\Common Files\Nokia\MPlatform\NokiaMServer.exe
(Google Inc.) C:\Documents and Settings\USER\Local Settings\Application Data\Google\Update\GoogleUpdate.exe
(Sony) C:\Program Files\Sony\Sony PC Companion\PCCompanion.exe
(Piriform Ltd) C:\Program Files\CCleaner\CCleaner.exe
() C:\Program Files\Sony\Sony PC Companion\PCCompanionInfo.exe
(McAfee, Inc.) C:\Program Files\McAfee Security Scan\2.0.181\SSScheduler.exe
() C:\Program Files\USB all-in-one game controller\GM_DevUpdate.exe
(Oracle Corporation) C:\Program Files\Oracle\JavaFX 2.1 Runtime\bin\jqs.exe
(Microsoft Corporation) C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
(GoldSolution Software, Inc.) C:\Program Files\PC Auto Shutdown\ShutdownService.exe
(Sun Microsystems, Inc.) C:\Program Files\Common Files\Java\Java Update\jucheck.exe
(Google Inc.) C:\Documents and Settings\USER\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
==================== Registry (Whitelisted) ==================
(If an entry is included in the fixlist, the registry item will be restored to default or removed. The file will not be moved.)
HKLM\...\Run: [RTHDCPL] => C:\WINDOWS\RTHDCPL.EXE [17331200 2012-02-10] (Realtek Semiconductor Corp.)
HKLM\...\Run: [Alcmtr] => C:\WINDOWS\ALCMTR.EXE [57344 2012-02-10] (Realtek Semiconductor Corp.)
HKLM\...\Run: [NvMediaCenter] => RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
HKLM\...\Run: [NvCplDaemon] => RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
HKLM\...\Run: [NeroFilterCheck] => C:\WINDOWS\system32\NeroCheck.exe [155648 2001-07-09] (Ahead Software Gmbh)
HKLM\...\Run: [sunJavaUpdateSched] => C:\Program Files\Common Files\Java\Java Update\jusched.exe [252296 2012-01-17] (Sun Microsystems, Inc.)
HKLM\...\Run: [] => [X]
HKLM\...\Run: [AdobeAAMUpdater-1.0] => C:\Program Files\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [499608 2011-03-15] (Adobe Systems Incorporated)
HKLM\...\Run: [switchBoard] => C:\Program Files\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Adobe Systems Incorporated)
HKLM\...\Run: [AdobeCS5.5ServiceManager] => C:\Program Files\Common Files\Adobe\CS5.5ServiceManager\CS5.5ServiceManager.exe [1523360 2011-01-12] (Adobe Systems Incorporated)
HKLM\...\Run: [start WingMan Profiler] => C:\Program Files\Logitech\Gaming Software\LWEMon.exe [153672 2010-06-14] (Logitech Inc.)
HKLM\...\Run: [APSDaemon] => C:\Program Files\Common Files\Apple\Apple Application Support\APSDaemon.exe [59280 2012-10-11] (Apple Inc.)
HKLM\...\Run: [QuickTime Task] => C:\Program Files\QuickTime\QTTask.exe [421888 2012-10-25] (Apple Inc.)
HKLM\...\Run: [NokiaMServer] => C:\Program Files\Common Files\Nokia\MPlatform\NokiaMServer /watchfiles
HKLM\...\Run: [PC Auto Shutdown] => C:\Program Files\PC Auto Shutdown\AutoShutdown.exe [1442472 2014-09-15] (GoldSolution Software, Inc.)
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\Run: [Google Update] => C:\Documents and Settings\USER\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [136176 2012-02-10] (Google Inc.)
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\Run: [DAEMON Tools Lite] => C:\Program Files\DAEMON Tools Lite\DTLite.exe [3477312 2012-01-19] (DT Soft Ltd)
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\Run: [sony PC Companion] => C:\Program Files\Sony\Sony PC Companion\PCCompanion.exe [468192 2014-10-15] (Sony)
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\Run: [KillCopy] => C:\WINDOWS\system32\killcopy.exe [1185792 2006-10-29] (Killer{R})
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\Run: [CCleaner Monitoring] => C:\Program Files\CCleaner\CCleaner.exe [5489944 2014-12-12] (Piriform Ltd)
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\MountPoints2: {0fe8f172-dcb2-11e2-81e4-00252207b9ad} - J:\AutoRun.exe
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\MountPoints2: {1c77e5ef-5531-11e3-8263-00252207b9ad} - J:\Startme.exe
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\MountPoints2: {a27c8692-53ed-11e1-bfe5-00252207b9ad} - F:\Setup.exe
HKU\S-1-5-21-220523388-842925246-839522115-1003\...\MountPoints2: {a27c86b7-53ed-11e1-bfe5-00252207b9ad} - F:\Setup.exe
Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\FlexType 2K.lnk
ShortcutTarget: FlexType 2K.lnk -> C:\WINDOWS\Datecs\Flex2K.exe ()
Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk
ShortcutTarget: McAfee Security Scan Plus.lnk -> C:\Program Files\McAfee Security Scan\2.0.181\SSScheduler.exe (McAfee, Inc.)
Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Nokia Ovi Suite.lnk
ShortcutTarget: Nokia Ovi Suite.lnk -> D:\Program Files\Nokia\Ovi\Suite\RunLauncher.exe (Nokia)
Startup: C:\Documents and Settings\USER\Start Menu\Programs\Startup\GM_DevUpdate.lnk
ShortcutTarget: GM_DevUpdate.lnk -> C:\Program Files\USB all-in-one game controller\GM_DevUpdate.exe ()
GroupPolicy: Group Policy on Chrome detected <======= ATTENTION
CHR HKLM\SOFTWARE\Policies\Google: Policy restriction <======= ATTENTION
==================== Internet (Whitelisted) ====================
(If an item is included in the fixlist, if it is a registry item it will be removed or restored to default.)
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.com
HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.microsoft.com/isapi/redir.dll?prd=ie&pver=6&ar=msnhome
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch
HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
HKU\S-1-5-21-220523388-842925246-839522115-1003\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.google.com/ie
HKU\S-1-5-21-220523388-842925246-839522115-1003\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://www.google.com/ie
URLSearchHook: HKU\S-1-5-21-220523388-842925246-839522115-1003 - Microsoft Url Search Hook - {CFBFAE00-17A6-11D0-99CB-00C04FD64497} - C:\WINDOWS\system32\shdocvw.dll (Microsoft Corporation)
HKLM\SOFTWARE\Microsoft\Internet Explorer\AboutURLs,Tabs: "" <======= ATTENTION
SearchScopes: HKLM -> DefaultScope value is missing.
SearchScopes: HKU\S-1-5-21-220523388-842925246-839522115-1003 -> {6A1806CD-94D4-4689-BA73-E35EA1EA9990} URL = http://www.google.com/search?q={sear
BHO: Java Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files\Oracle\JavaFX 2.1 Runtime\bin\ssv.dll (Oracle Corporation)
BHO: WatchItAdBaloccke -> {B2E843CC-3C5B-E701-E9AC-890CBB524C72} -> C:\Documents and Settings\All Users\Application Data\WatchItAdBaloccke\CJca1yvaQ.dll ()
BHO: IsAvero -> {D2906719-1233-0362-21FD-B396D6189892} -> C:\Documents and Settings\All Users\Application Data\IsAvero\AJlWe3jRP.dll ()
BHO: Java Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files\Oracle\JavaFX 2.1 Runtime\bin\jp2ssv.dll (Oracle Corporation)
BHO: AAlliSSavier -> {E1254057-2786-8347-11F0-6EB2DEEB8600} -> C:\Documents and Settings\All Users\Application Data\AAlliSSavier\mlVmqnk.dll ()
Handler: ms-itss - {0A9007C0-4076-11D3-8789-0000F8105754} - C:\Program Files\Common Files\Microsoft Shared\Information Retrieval\MSITSS.DLL (Microsoft Corporation)
Tcpip\Parameters: [DhcpNameServer] 192.168.1.1
FireFox:
FF ProfilePath: C:\Documents and Settings\USER\Application Data\Mozilla\Firefox\Profiles\l5agnx6k.default
FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF32_15_0_0_223.dll ()
FF Plugin: @adobe.com/ShockwavePlayer -> C:\WINDOWS\system32\Adobe\Director\np32dsw_1168638.dll (Adobe Systems, Inc.)
FF Plugin: @Google.com/GoogleEarthPlugin -> C:\Program Files\Google\Google Earth\plugin\npgeplugin.dll (Google)
FF Plugin: @google.com/npPicasa3,version=3.0.0 -> C:\Program Files\Google\Picasa3\npPicasa3.dll (Google, Inc.)
FF Plugin: @java.com/DTPlugin,version=10.4.1 -> C:\WINDOWS\system32\npDeployJava1.dll (Oracle Corporation)
FF Plugin: @java.com/JavaPlugin,version=10.4.1 -> C:\Program Files\Oracle\JavaFX 2.1 Runtime\bin\plugin2\npjp2.dll (Oracle Corporation)
FF Plugin: @microsoft.com/WPF,version=3.5 -> C:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\NPWPF.dll (Microsoft Corporation)
FF Plugin: @tools.google.com/Google Update;version=3 -> C:\Program Files\Google\Update\1.3.23.9\npGoogleUpdate3.dll (Google Inc.)
FF Plugin: @tools.google.com/Google Update;version=9 -> C:\Program Files\Google\Update\1.3.23.9\npGoogleUpdate3.dll (Google Inc.)
FF Plugin HKU\S-1-5-21-220523388-842925246-839522115-1003: @tools.google.com/Google Update;version=3 -> C:\Documents and Settings\USER\Local Settings\Application Data\Google\Update\1.3.22.3\npGoogleUpdate3.dll (Google Inc.)
FF Plugin HKU\S-1-5-21-220523388-842925246-839522115-1003: @tools.google.com/Google Update;version=9 -> C:\Documents and Settings\USER\Local Settings\Application Data\Google\Update\1.3.22.3\npGoogleUpdate3.dll (Google Inc.)
FF SearchPlugin: C:\Program Files\mozilla firefox\searchplugins\911bg.xml
FF SearchPlugin: C:\Program Files\mozilla firefox\searchplugins\diribg.xml
FF SearchPlugin: C:\Program Files\mozilla firefox\searchplugins\pe-bg.xml
FF SearchPlugin: C:\Program Files\mozilla firefox\searchplugins\portalbgdict.xml
FF Extension: DownloadHelper - C:\Documents and Settings\USER\Application Data\Mozilla\Firefox\Profiles\l5agnx6k.default\Extensions\{b9db16a4-6edc-47ec-a1f4-b86292ed211d} [2012-03-25]
FF Extension: DownThemAll! - C:\Documents and Settings\USER\Application Data\Mozilla\Firefox\Profiles\l5agnx6k.default\Extensions\{DDC359D1-844A-42a7-9AA1-88A850A938A8}.xpi [2012-03-15]
FF HKLM\...\Firefox\Extensions: [{20a82645-c095-46ed-80e3-08825760534b}] - C:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension
FF Extension: Microsoft .NET Framework Assistant - C:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension [2013-05-23]
Chrome:
CHR Profile: C:\Documents and Settings\USER\Local Settings\Application Data\Google\Chrome\User Data\Default
CHR Extension: (Adblock Plus) - C:\Documents and Settings\USER\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\cfhdojbkjhnklbpkdaibdccddilifddb [2014-07-21]
CHR Extension: (Отдалечен работен плот на Chrome) - C:\Documents and Settings\USER\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\gbchcmhmhahfdphkhkmpfmihenigjmpp [2014-06-13]
CHR Extension: (WatchItAdBaloccke) - C:\Documents and Settings\USER\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\gmbljhkcgldnegdmapofijpccfjmddil [2014-02-05]
CHR Extension: (Google Wallet) - C:\Documents and Settings\USER\Local Settings\Application Data\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2013-08-24]
CHR StartMenuInternet: Google Chrome - C:\Documents and Settings\USER\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
========================== Services (Whitelisted) =================
(If an entry is included in the fixlist, the service will be removed from the registry. The file will not be moved unless listed separately.)
S3 chromoting; C:\Program Files\Google\Chrome Remote Desktop\35.0.1916.52\remoting_host.exe [51016 2014-04-17] (Google Inc.)
S3 IDriverT; C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe [69632 2005-04-03] (Macrovision Corporation) [File not signed]
R2 JavaQuickStarterService; C:\Program Files\Oracle\JavaFX 2.1 Runtime\bin\jqs.exe [161664 2012-04-04] (Oracle Corporation)
S3 McComponentHostService; C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe [227232 2010-01-15] (McAfee, Inc.)
R2 PCAutoShutdown_Service; C:\Program Files\PC Auto Shutdown\ShutdownService.exe [442136 2011-11-14] (GoldSolution Software, Inc.)
S3 ServiceLayer; D:\Program Files\Nokia\PC Connectivity Solution\ServiceLayer.exe [572416 2008-05-30] (Nokia.) [File not signed]
S3 Sony PC Companion; C:\Program Files\Sony\Sony PC Companion\PCCService.exe [155824 2013-02-04] (Avanquest Software)
S3 SwitchBoard; C:\Program Files\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Adobe Systems Incorporated) [File not signed]
S2 e64a4d03; "C:\WINDOWS\system32\rundll32.exe" "c:\docume~1\alluse~1\applic~1\assist~1\AssistantSvc.dll",service
==================== Drivers (Whitelisted) ====================
R2 atksgt; C:\WINDOWS\System32\DRIVERS\atksgt.sys [165376 2012-06-10] () [File not signed]
R1 dtsoftbus01; C:\WINDOWS\System32\DRIVERS\dtsoftbus01.sys [242240 2012-02-10] (DT Soft Ltd)
R1 eusk2par; C:\WINDOWS\system32\Drivers\eusk2par.sys [30656 2006-12-13] (Eutron)
R0 giveio; C:\WINDOWS\System32\giveio.sys [5248 1996-04-03] () [File not signed]
U3 GMFilter; C:\WINDOWS\system32\Drivers\GMFilter.sys [20992 2004-12-16] () [File not signed]
R2 lirsgt; C:\WINDOWS\System32\DRIVERS\lirsgt.sys [18048 2012-06-10] () [File not signed]
R3 nv; C:\WINDOWS\System32\DRIVERS\nv4_mini.sys [9902112 2010-08-19] (NVIDIA Corporation) [File not signed]
R0 PxHelp20; C:\WINDOWS\System32\Drivers\PxHelp20.sys [20640 2005-12-05] (Sonic Solutions) [File not signed]
S3 s0016bus; C:\WINDOWS\System32\DRIVERS\s0016bus.sys [89256 2008-05-16] (MCCI Corporation)
S3 s0016mdfl; C:\WINDOWS\System32\DRIVERS\s0016mdfl.sys [15016 2008-05-16] (MCCI Corporation)
S3 s0016mdm; C:\WINDOWS\System32\DRIVERS\s0016mdm.sys [120744 2008-05-16] (MCCI Corporation)
S3 s0016mgmt; C:\WINDOWS\System32\DRIVERS\s0016mgmt.sys [114216 2008-05-16] (MCCI Corporation)
S3 s0016nd5; C:\WINDOWS\System32\DRIVERS\s0016nd5.sys [25512 2008-05-16] (MCCI Corporation)
S3 s0016obex; C:\WINDOWS\System32\DRIVERS\s0016obex.sys [110632 2008-05-16] (MCCI Corporation)
S3 s0016unic; C:\WINDOWS\System32\DRIVERS\s0016unic.sys [115752 2008-05-16] (MCCI Corporation)
R2 Secdrv; C:\WINDOWS\System32\DRIVERS\secdrv.sys [12464 2012-02-10] (Macrovision Europe Ltd) [File not signed]
R0 sfdrv01; C:\WINDOWS\System32\drivers\sfdrv01.sys [50688 2005-08-10] (Protection Technology) [File not signed]
R0 sfhlp02; C:\WINDOWS\System32\drivers\sfhlp02.sys [6656 2005-05-16] (Protection Technology) [File not signed]
R0 sfvfs02; C:\WINDOWS\System32\drivers\sfvfs02.sys [66048 2005-09-29] (Protection Technology) [File not signed]
R3 skbusenum; C:\WINDOWS\System32\DRIVERS\skbusenum.sys [10880 2004-12-16] (Windows ® 2000 DDK provider) [File not signed]
R0 speedfan; C:\WINDOWS\System32\speedfan.sys [25240 2011-03-18] (Almico Software)
S3 upperdev; C:\WINDOWS\System32\DRIVERS\usbser_lowerflt.sys [8064 2008-06-06] (Windows ® Codename Longhorn DDK provider)
S3 UsbserFilt; C:\WINDOWS\System32\DRIVERS\usbser_lowerfltj.sys [8064 2008-05-07] (Windows ® Codename Longhorn DDK provider)
R0 VirtualK; C:\WINDOWS\System32\drivers\VirtualK.sys [3968 2003-11-27] (Windows ® 2000 DDK provider) [File not signed]
R3 WmBEnum; C:\WINDOWS\System32\drivers\WmBEnum.sys [22856 2010-04-27] (Logitech Inc.)
S3 WmFilter; C:\WINDOWS\System32\drivers\WmFilter.sys [37704 2010-04-27] (Logitech Inc.)
S3 WmHidLo; C:\WINDOWS\System32\drivers\WmHidLo.sys [31816 2010-04-27] (Logitech Inc.)
R3 WmVirHid; C:\WINDOWS\System32\drivers\WmVirHid.sys [15048 2010-04-27] (Logitech Inc.)
R3 WmXlCore; C:\WINDOWS\System32\drivers\WmXlCore.sys [66632 2010-04-27] (Logitech Inc.)
S1 EterlogicVirtualSerialDriver; \??\C:\DOCUME~1\USER\LOCALS~1\Temp\VSPE.sys [X]
S4 IntelIde; No ImagePath
U1 WS2IFSL; No ImagePath
==================== NetSvcs (Whitelisted) ===================
(If an item is included in the fixlist, it will be removed from the registry. Any associated file could be listed separately to be moved.)
==================== One Month Created Files and Folders ========
(If an entry is included in the fixlist, the file\folder will be moved.)
2014-12-25 21:05 - 2014-12-25 21:05 - 00000000 ____D () C:\FRST
2014-12-25 21:03 - 2014-12-25 21:03 - 00057008 _____ () C:\Documents and Settings\USER\Desktop\Extras.Txt
2014-12-25 21:02 - 2014-12-25 21:02 - 00067834 _____ () C:\Documents and Settings\USER\Desktop\OTL.Txt
2014-12-25 20:55 - 2014-12-25 20:56 - 00602112 _____ (OldTimer Tools) C:\Documents and Settings\USER\Desktop\OTL.exe
2014-12-25 20:51 - 2014-12-25 20:51 - 03563072 _____ () C:\WINDOWS\system32\FNTCACHE.DAT
2014-12-25 18:07 - 2014-12-25 18:07 - 00005122 _____ () C:\Documents and Settings\USER\My Documents\cc_20141225_180743.reg
2014-12-25 18:02 - 2014-12-25 18:02 - 00000682 _____ () C:\Documents and Settings\All Users\Desktop\CCleaner.lnk
2014-12-25 01:14 - 2014-12-25 01:14 - 00000000 ____D () C:\Program Files\KillSoft
2014-12-25 01:14 - 2014-12-25 01:14 - 00000000 ____D () C:\Documents and Settings\USER\Start Menu\Programs\KillCopy
2014-12-25 01:11 - 2014-12-25 20:56 - 00000000 ____D () C:\Documents and Settings\USER\Application Data\TeraCopy
2014-12-25 01:11 - 2014-12-25 01:11 - 00000000 ____D () C:\Program Files\TeraCopy
2014-12-25 01:11 - 2014-12-25 01:11 - 00000000 ____D () C:\Documents and Settings\All Users\Start Menu\Programs\TeraCopy
2014-12-25 00:54 - 2014-12-25 00:54 - 00000000 ____D () C:\Program Files\FastCopy
2014-12-17 23:00 - 2014-12-17 23:00 - 00000000 ____D () C:\Documents and Settings\USER\My Documents\Rockstar Games
2014-12-17 22:51 - 2014-12-17 22:51 - 00000000 __SHD () C:\Documents and Settings\All Users\Application Data\SecuROM
2014-12-17 22:51 - 2014-12-17 22:51 - 00000000 ____D () C:\Documents and Settings\USER\Local Settings\Application Data\Rockstar Games
2014-12-17 22:37 - 2014-12-17 22:37 - 00000581 _____ () C:\Documents and Settings\USER\Desktop\Grand Theft Auto IV - Winter.lnk
2014-12-17 22:37 - 2014-12-17 22:37 - 00000000 ____D () C:\Documents and Settings\USER\Start Menu\Programs\Grand Theft Auto IV - Winter
2014-12-08 00:18 - 2014-12-08 00:18 - 00000019 _____ () C:\Documents and Settings\USER\Desktop\wrc.txt
2014-12-03 01:14 - 2014-12-03 01:21 - 00000000 ____D () C:\Documents and Settings\USER\Desktop\Pejo skoda
2014-11-30 19:13 - 2014-11-30 19:44 - 00000000 ____D () C:\Documents and Settings\USER\Desktop\29.11.2014
==================== One Month Modified Files and Folders =======
2014-12-25 21:05 - 2012-02-10 12:04 - 00000000 ____D () C:\Documents and Settings\USER\Local Settings\Temp
2014-12-25 20:58 - 2012-02-10 11:53 - 00354841 _____ () C:\WINDOWS\WindowsUpdate.log
2014-12-25 20:56 - 2012-02-28 22:02 - 00000982 _____ () C:\WINDOWS\Tasks\GoogleUpdateTaskMachineUA.job
2014-12-25 20:56 - 2012-02-10 15:23 - 00000000 ____D () C:\Documents and Settings\USER\Desktop\_2
2014-12-25 20:56 - 2012-02-10 13:43 - 00000263 _____ () C:\WINDOWS\wiadebug.log
2014-12-25 20:56 - 2012-02-10 13:39 - 00521942 _____ () C:\WINDOWS\system32\PerfStringBackup.INI
2014-12-25 20:52 - 2012-02-10 13:43 - 00000053 _____ () C:\WINDOWS\wiaservc.log
2014-12-25 20:51 - 2014-01-08 00:02 - 00000610 ____H () C:\WINDOWS\Tasks\GS.Enabler-S-848671963.job
2014-12-25 20:51 - 2012-02-28 22:02 - 00000978 _____ () C:\WINDOWS\Tasks\GoogleUpdateTaskMachineCore.job
2014-12-25 20:51 - 2012-02-10 12:01 - 00000006 ____H () C:\WINDOWS\Tasks\SA.DAT
2014-12-25 20:51 - 2004-08-04 03:07 - 00002206 _____ () C:\WINDOWS\system32\wpa.dbl
2014-12-25 20:11 - 2012-02-10 12:48 - 00001074 _____ () C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-220523388-842925246-839522115-1003UA.job
2014-12-25 18:11 - 2012-02-10 12:01 - 00032500 _____ () C:\WINDOWS\SchedLgU.Txt
2014-12-25 18:09 - 2014-11-09 01:48 - 00000000 ____D () C:\Documents and Settings\All Users\Start Menu\Programs\Street Legal Racing - Redline NF 2010
2014-12-25 18:09 - 2013-02-10 21:53 - 00000000 ____D () C:\Documents and Settings\USER\Desktop\др
2014-12-25 18:07 - 2012-11-13 16:24 - 00000000 ____D () C:\Program Files\Steam
2014-12-25 18:07 - 2012-02-10 18:29 - 00000000 ____D () C:\Documents and Settings\USER\Application Data\DAEMON Tools Lite
2014-12-25 18:06 - 2012-02-10 12:49 - 00000000 ____D () C:\Documents and Settings\USER\Application Data\uTorrent
2014-12-25 18:05 - 2012-11-20 20:55 - 00000000 ____D () C:\Program Files\SpeedFan
2014-12-25 18:05 - 2012-04-01 17:20 - 00000000 ____D () C:\WINDOWS\Minidump
2014-12-25 18:02 - 2012-10-30 15:19 - 00000000 ____D () C:\Program Files\CCleaner
2014-12-25 11:11 - 2013-05-16 14:03 - 00001022 _____ () C:\WINDOWS\Tasks\GoogleUpdateTaskUserS-1-5-21-220523388-842925246-839522115-1003Core1ce522d61660a2a.job
2014-12-25 02:00 - 2012-09-13 23:58 - 00000340 _____ () C:\WINDOWS\Tasks\AdobeAAMUpdater-1.0-PC-USER.job
2014-12-23 04:01 - 2012-02-10 12:04 - 00000178 ___SH () C:\Documents and Settings\USER\ntuser.ini
2014-12-18 20:15 - 2014-10-08 19:23 - 00000000 ____D () C:\temp
2014-12-17 17:52 - 2012-12-17 16:38 - 00000000 ____D () C:\Documents and Settings\All Users\Start Menu\Programs\Wenson
2014-12-17 17:50 - 2012-12-17 16:36 - 00000000 ____D () C:\WINDOWS\Downloaded Installations
2014-12-17 17:50 - 2012-04-13 23:49 - 00000000 ____D () C:\Documents and Settings\USER\Desktop\Простотииии
2014-12-16 21:34 - 2014-10-09 00:21 - 00000000 ____D () C:\Documents and Settings\USER\My Documents\Euro Truck Simulator 2
2014-12-03 23:50 - 2012-02-11 15:47 - 00000000 ____D () C:\Documents and Settings\USER\My Documents\Rigs of Rods 0.38
2014-12-02 16:55 - 2013-04-19 11:06 - 00001739 _____ () C:\Documents and Settings\All Users\Desktop\Sony PC Companion 2.1.lnk
2014-12-02 16:55 - 2012-03-08 17:15 - 00000000 ____D () C:\Documents and Settings\All Users\Start Menu\Programs\Sony
2014-12-02 16:54 - 2012-02-10 12:15 - 00000000 ___HD () C:\Program Files\InstallShield Installation Information
Some content of TEMP:
C:\Documents and Settings\USER\Local Settings\Temp\NEventMessages.dll
C:\Documents and Settings\USER\Local Settings\Temp\sfamcc00001.dll
C:\Documents and Settings\USER\Local Settings\Temp\sfamcc00002.dll
==================== Bamital & volsnap Check =================
(There is no automatic fix for files that do not pass verification.)
C:\WINDOWS\explorer.exe => File is digitally signed
C:\WINDOWS\system32\winlogon.exe => File is digitally signed
C:\WINDOWS\system32\svchost.exe => File is digitally signed
C:\WINDOWS\system32\services.exe => File is digitally signed
C:\WINDOWS\system32\User32.dll => File is digitally signed
C:\WINDOWS\system32\userinit.exe => File is digitally signed
C:\WINDOWS\system32\rpcss.dll => File is digitally signed
C:\WINDOWS\system32\Drivers\volsnap.sys => File is digitally signed
==================== End Of Log ============================
Addition.txt
Защп мислите че е вирус ?
Първо опитайте да ги свалите на друг компютър, или ако клиповете не са важни, да форматирате камерата защото клиповете може да са се пре....
Имал съм такъв случай, с една обикновенна камера, клиповете се бяха пре..... и не можеха да се копират.
Пробвах колега не стана с форматиране  :(  преди това свалих 10-тина клипа и немаше проблеми и сега започнаха а камерата е чисто нова на 2 дена
Здравейте..! :)
Само като видях това:
....и си помислих че трябва да спрем да правим каквото и да е друго..!
remove%20outdated.jpg Деинсталиране нa програми
Изтеглете програмата GeekUninstaller и я запазете на десктопа.
Разархивирайте я и стартирайте файла geek.exe IxXO5oO.jpg  От списъка намерете и деинсталирайте всички програми които съм ви написал в карето:
AAlliSSavier
IsAvero
WatchItAdBaloccke
Кликнете с десен бутон върху програмата и изберете Uninstall
След края на всяка деинсталацията ще се отвори прозорец подканващ ви да премахнете всички остатъци от програмата (ако има такива, ако няма този прозорец няма да се появи):
Пример:
Натиснете бутона Finish за да изтриете останките от програмата.
adwcleaner_new.png Сканиране с AdwCleaner
Моля, изтеглете и стартирайте програмата AdwCleaner (by Xplode):
  • Затворете всички стартирани програми и браузъри
  • Кликнете два пъти върху adwcleaner.exe за да стартирате инструмента.
  • Натиснете OK, за да потвърдите, че всички стартирани програми ще бъдат затворени.
  • Маркирайте Clean
  • Вашият компютър ще се рестартира автоматично. Текстовия файл ще се отвори след рестарта.
  • Моля, да публикувате съдържанието на този лог в отговора си
  • Можете да намерите лога,който автоматично се запомня тук C:AdwCleaner[s0].txt
JRTbythisisu.png Сканиране с Junkware Removal Tool
Моля, изтеглете Junkware Removal Tool (by Thisisu ) и запазете на вашия десктоп.
  • Спрете временно работата на защитните програми.
  • Стартирайте инструмента JRT.exe
  • Ще се отвори ДОС прозорец. Натиснете което и да е копче от клавиатурата.
  • Затворете излишните приложения и всички браузъри и изчакайте проверката да завърши.
  • Ще се появи лог файл (който можете да намерите и ръчно на десктопа с името JRT.txt).
  • Моля копирайте съдържанието на лог файла в следващия си пост.
FRST.gif Сканиране с Farbar Recovery Scan Tool
Повторете сканирането с Farbar Recovery Scan Tool
xpfNZP4A.png.pagespeed.ic.bp5cRl1pJg.jpg  Дневници
В следващия си отговор, моля да включите следните дневници:
  • FRST.txt
  • Addition.txt
  • JRT.txt
  • AdwCleaner[s0].txt
