Проблем с интернет връзката след инсталирана програма Relevant Knowledge
Здравей :)
мисля че нещата драстично се промениха, вече ги няма тези линкове, както имаше 1 виц за лъва и магарето - не си Цар, Бог си :D
Прикачвам ти една снимка, да видиш папките, които имам в C:/ дали някой не трябва да ги махна?
http://prikachi.com/images.php?images/550/7732550y.jpg
Гледах че с този последния фикс тези found1..2...3 са махнати :D
ето и лога.
All processes killed
========== OTL ==========
Prefs.js: "false" removed from browser.search.useDBForOrder
Prefs.js: %7B58e3c1c9-2dc1-4762-bd45-1df9da9d0820%7D:0.2 removed from extensions.enabledAddons
C:\Users\Krivoshiyski\AppData\Roaming\Mozilla\Firefox\Profiles\qvnocx9x.default\extensions\{58e3c1c9-2dc1-4762-bd45-1df9da9d0820}\modules folder moved successfully.
C:\Users\Krivoshiyski\AppData\Roaming\Mozilla\Firefox\Profiles\qvnocx9x.default\extensions\{58e3c1c9-2dc1-4762-bd45-1df9da9d0820}\chrome\skin\classic folder moved successfully.
C:\Users\Krivoshiyski\AppData\Roaming\Mozilla\Firefox\Profiles\qvnocx9x.default\extensions\{58e3c1c9-2dc1-4762-bd45-1df9da9d0820}\chrome\skin folder moved successfully.
C:\Users\Krivoshiyski\AppData\Roaming\Mozilla\Firefox\Profiles\qvnocx9x.default\extensions\{58e3c1c9-2dc1-4762-bd45-1df9da9d0820}\chrome\content folder moved successfully.
C:\Users\Krivoshiyski\AppData\Roaming\Mozilla\Firefox\Profiles\qvnocx9x.default\extensions\{58e3c1c9-2dc1-4762-bd45-1df9da9d0820}\chrome folder moved successfully.
C:\Users\Krivoshiyski\AppData\Roaming\Mozilla\Firefox\Profiles\qvnocx9x.default\extensions\{58e3c1c9-2dc1-4762-bd45-1df9da9d0820} folder moved successfully.
C:\Users\Krivoshiyski\AppData\Roaming\Mozilla\Firefox\Profilesqvnocx9x.default\extensions\staged\{d6b1a471-3776-48de-90e2-a0d90de70fd3} folder moved successfully.
C:\Users\Krivoshiyski\AppData\Roaming\Mozilla\Firefox\Profilesqvnocx9x.default\extensions\staged folder moved successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\10 deleted successfully.
C:\found.000\dir0000.chk folder moved successfully.
C:\found.000 folder moved successfully.
C:\found.001\dir0000.chk folder moved successfully.
C:\found.001 folder moved successfully.
C:\found.002\dir0000.chk folder moved successfully.
C:\found.002 folder moved successfully.
C:\found.003\dir0000.chk folder moved successfully.
C:\found.003 folder moved successfully.
C:\found.004\dir0000.chk folder moved successfully.
C:\found.004 folder moved successfully.
C:\found.005 folder moved successfully.
C:\found.006\dir0000.chk folder moved successfully.
C:\found.006 folder moved successfully.
C:\found.007 folder moved successfully.
C:\Program Files (x86)\GUM8564.tmp folder moved successfully.
========== FILES ==========
File\Folder c:\program files (x86)\relevantknowledge not found.
< netsh winsock reset catalog /c >
Sucessfully reset the Winsock Catalog.
You must restart the computer in order to complete the reset.
C:\Users\Krivoshiyski\Desktop\cmd.bat deleted successfully.
C:\Users\Krivoshiyski\Desktop\cmd.txt deleted successfully.
< ipconfig /flushdns /c >
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
========== REGISTRY ==========
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{F8888D50-66EA-4BEA-97EB-8EF6B769F4DF} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F8888D50-66EA-4BEA-97EB-8EF6B769F4DF}\ not found.
========== COMMANDS ==========
[EMPTYTEMP]
User: All Users
User: Default
->Temp folder emptied: 0 bytes
->Temporary Internet Files folder emptied: 0 bytes
User: Default User
User: Krivoshiyski
->Temp folder emptied: 4717264 bytes
->Temporary Internet Files folder emptied: 592400 bytes
->FireFox cache emptied: 36323773 bytes
->Google Chrome cache emptied: 86075406 bytes
->Flash cache emptied: 1353 bytes
User: Public
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 0 bytes
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 1216 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 128 bytes
RecycleBin emptied: 806 bytes
Total Files Cleaned = 122,00 mb
C:\Windows\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
OTL by OldTimer - Version 3.2.69.0 log created on 11192014_183745
Files\Folders moved on Reboot...
C:\Users\Krivoshiyski\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
PendingFileRenameOperations files...
Registry entries deleted on Reboot...
Супер, радвам се, но чак Бог не съм :)
Няколко финални препоръки:
1. Проверете за стари приложения с помощта на PatchMyPC.
2. Почистете Java Cache и премахнете остатъците остатъците от предишните JAVA инсталации по следния начин:
  • Моля изтеглете JavaRa 2.6  и я разархивирайте на вашия десктоп.
  • Стартирайте файла JavaRa.exe.
  • Натиснете бутона Updata JavaRa Definitions и след това натиснете бутона Download. След като приключи просто натиснете бутона ОК.
  • Сега натиснете Remove JRE, тъй като вече деинсталирахте всички версии на JAVA в началото просто натиснете бутона Next.
  • Сега натиснете Perform Removal Routine за да премахнете всички остатъци от JAVA в регистъра и от компютъра.
  • Когато приключи натиснете бутона OK за да затворите съобщението.
  • Изберете Next за да пропуснете download процеса. Изберете бутона Next още веднъж.Сега изберете бутона Close this wizard и натиснете Finish.
  • От основното меню изберете сега Additional tasks.
  • Сложете отметка пред Remove startup entry, Remove Outdated JRE Firefox Extentions и Clean JRE Temp Files и натиснете бутона Run. Браузърите трябва да бъде затворени преди да се опитате да изпълните тази стъпка!
  • След като приключи успешно, ще видите съобщението: "Selected tasks completed successfully".
  • Ще се създаде лог файл в същата папка от която сте стартирали JavaRa.
  • Моля, публикувайте този файл в следващия си коментар. Ако е много голям го качете на dox.bg.
  • Затворете JavaRa с натискането на червения хикс.
3. За да почистим използваните от нас инструменти направете следното:
3.1 Отворете Start => в полето за търсене въведете командата Combofix /Uninstall (има място между Combofix и /Uninstall) и натиснете Enter
3.2 Стартирайте OTL още веднъж и натиснете бутона CleanUp.
Ако бъдете подканени да рестартирате, се съгласете.
3.3 Изтеглете Delfix.exe и го стартирайте. Сложете отметка пред Remove disinfection tools (трябва да има такава по-подразбиране, но все пак да си кажа) => натиснете бутона Run
Инструмента ще се самоизтрие след като приключи своята задача! Ако има папки, които не са се изтрили след гореспоменатите процедури пишете и ще ги премахнем ръчно.
4. За подобряване на производителността (ако системата ви се вижда мудна) вижте следните няколко теми:
Оптимизиране на Windows с цел по-добра производителност
Ръководство за поддръжка на Windows (XP, Vista и 7) [Revision 2.0]
Какво да направя, ако компютърът ми работи бавно
Профилактика на компютъра,как?
Направете и една дефрагментация с MyDefrag за повишаване на производителноста при дисковите операции: (ще се отрази благоприятно и при често използваните програми):
Изтеглете MyDefrag и я инсталирайте.
Изтеглете следния архив и го разархивирайте в C:\Program Files\MyDefrag v4.3.1\Scripts
Стартирайте MyDefrag.exe и изберете System Disk Level V и посочете системния дял C: и натиснете Run
Може да отнеме доста време, защото за основа на скрипта са използвани скриптовете на Jaspion и на някои други потребители + мои лични настройки и модификации.
Скрипта ще направи приоритизация на често използваните програми и файлове.
След като приключи ще изпише Finished и можете да затворите програмата от X-са.
Рестартирайте системата.
5. Проверете системата си актуални драйвери от сайтовете на производителите на компонентите ако ви се занимава (не използвайте програми за автоматично обновяване на драйверите за да си спестите главоболията после) и направете пълна проверка за гадини с наличната ви антивирусна програма за всеки случай (защото тя все пак е базирана на дефиниции и ние може да сме изтървали нещо тъй като почистваме само това, което видим в логовете).
Поздрави и усмихната седмица! Ще маркирам случая като РЕШЕН! :bye1:
