Специфични средства за борба със зловреден софтуер и Standalone вирус скенери
Mалко със закъснение за тези, които използват mvps hosts. За пореден път могат да се възползват безплатно от ъпдейта. Ето го host файла: тук (02.04.2013).
  • Отговори 365
  • Прегледи 209,8k
Полезен инструмент с много функции
  D7 Free
Providing one-click automation for:
Virus / Malware Removal [*]Windows Repair and Maintenance [*]Data Backup / Restore [*]System Info / Reporting [*]Keeping all of your tools updated!
Кратко ревю
Има още доста клипчета.
Официална страница:http://www.foolishit.com/d7/
Изтегляне: http://www.majorgeeks.com/files/details/d7.html
OS: Win 8 / Win 7 / Vista/ XP
  • 2 месеца по-късно...
BullGuard launches free online virus scan
http://virus-scan.bullguard.com/
Онлайн скенер.
Emsisoft Emergency Kit 4.0 is a major update for improved user experience, performance and precision in malware removal.
  • The Emsisoft Emergency Kit Scanner draws upon the award-winning dual scan technology of Emsisoft Anti-Malware. Recent improvements to the cleaning engine ensure that malware removal is more thorough than ever. Naturally you are able to perform the removal yourself at no charge and our malware experts in the Emsisoft Support Forums are also available if you require advice or assistance.
  • The core strength of the Emsisoft Commandline Scanner lies in its ability to provide experienced users with an extensive set of parameters to check for malware infections via the command line.
  • Emsisoft Hijackfree allows you to manage all active processes, services, drivers, autoruns, open ports etc. for full control over your system. It helps advanced users to detect and remove all kinds of hijackers, malware, spyware, adware, trojans and worms manually.
  • Malware infections are not always easy to clean up. Emsisoft Blitzblank assists with stubborn infections by allowing for removal of infected files, registry entries and drivers at boot time before Windows loads and existing malware has a chance to activate its self-protection mechanisms.
http://support.emsisoft.com/topic/11841-emsisoft-emergency-kit-40012-released/
Голям ъпдейт. ;)
Нова версия AVZ - 4.41
Вышла новая версия антивирусной утилиты AVZ - 4.41. Архив с утилитой содержит базу вирусов от 12.07.2013 - 297614 сигнатур, 2 нейропрофиля, 56 микропрограмм лечения, 403 микропрограммы эвристики, 9 микропрограмм ИПУ, 236 микропрограммы поиска и устранения проблем, 565706 подписей безопасных файлов. Новая версия содержит ряд доработок и усовершенствований. Основные модификации: [++] Менеджер планировщика заданий - поддержка планировщика v2 (Vista, Win7, Win8) [++] Новый парсер сложной командной строки, выделяющий требующие внимания исполняемые файлы [++] Новый набор команд скрипт-языка для выполнения произвольных WMI запросов [++] Подключена возможность просмотра данных о файле в системе Kaspersky Application Advisor [++] В исследовании системы введена поддержка дополнительных проверок, хранящихся в обновляемой БД [++] В скрипт-языке новые функции AddFileInfoToXML, AddDataToXML, WMI_Init, WMI_Query, WMI_Fetch, WMI_GetField, WMI_Free, SleepMS, GetComputerIP, ClearXMLData [+] Изменена логика работы команды удаления файла - появился второй параметр, указывающий, в каком режиме редиректора следует выполнить удаление [+] Вывод в протокол исследования системы данных о расшаренных ресурсах (опционально, по умолчанию выключено) [+] Вывод в XML протокол данных о всех запущенных процессах, без фильтрации (опционально, по умолчанию выключено) [+] В мастере поиска и устранения проблем добавлено всплывающее меню, позволяющее выбрать все пукты, снять и инвертировать выделение [+] Добавлен режим шифрования файлов в карантине для исключения их удаления антивирусом [+/-] В скриптязыке изменена логика работы ExecuteScript - скриптам любого уровня разрешено изменять настройки AVZ [-] Исправлена проблема с тем, что в описание файла в карантине не попадали сведения о его атрибутах
http://z-oleg.com/secur/avz/download.php
  • 3 седмици по-късно...
  • 3 месеца по-късно...
HitmanPro.Alert 2.5 with CryptoGuard BETAChangelogADDED: CryptoGuard: a universal solution against crypto ransomware.More information: www.hitmanpro.com/alert/cryptoguardADDED: Support for Internet Explorer Enhanced Protected Mode.ADDED: Support for Opera 17
 Във форума на Wilders Security в директен контакт с erikloman се говори за това какво е, какво не е и как си върши работата този инструмент за защита срешу crypto ransomware. Оставам с впечатление за добри отзиви, но не видях резултати от реални тестове. Да се надявам ли на такива от  нашите специалисти, които си играят с още топли проби?
http://www.wilderssecurity.com/showthread.php?t=324841&page=32
http://www.piriform.com/agomo
Облачно решение за all-in-one поддръжка на системата от Piriform - създателите на CCleaner, Recuva и Defraggler. Все още в бета период.
Редактирано от Методи Дамянов (преглед на промените)
http://download.bitdefender.com/removal_tools/BDAntiCryptoLocker_Release.exe
Блокиращ криптирането на CryptoLocker инструмент от BitDefender.
Всъщност не е доста сносен, доста голям размер на файла заради по-готиното GUI и няма бели списъци. CryptoPrevent е по-добрата алтернатива и се обновява по-често. :)
Мхм...ровичках се за новини и попаднах на него... Нямам особено добро мнение за румънците, но им ползвам инструмента за имунизация на флашки, който е ок, та реших да шерна този инструмент...
                                                     HitmanPro.Alert 2.5.6 Build 61 BETA
   Доизпипали са програмката и са добавили нови възможности:
ChangelogADDED: CryptoGuard for Windows File Sharing (SMB).Protect your file shares against rogue endpoints by simply installing Alert on the file server. Requires Windows Server 2008 R2 or newer.ADDED: Alert writes remote crypto-ransomware attacks to Windows Event Log. The event data contains remote IP, local share name and the filenames under attack.ADDED: CryptoGuard minifilter driver now supports oplocks (64-bit only).ADDED: CryptoGuard minifilter driver now supports process and IP clustering (64-bit only).ADDED: Command line switch /flyout to configure flyout during command line based installations.IMPROVED: Fine-tuned CryptoGuard algorithm.IMPROVED: Installer and updater write to the Windows Event Log.IMPROVED: User interface now shows tiles representing Alert’s features.FIXED: CryptoGuard handling JPG files.FIXED: CryptoGuard working folder is cleaned up when computer shuts down.FIXED: Small kernel memory leak.FIXED: Alert is now compatible with Norton 360 and Norton Internet Security.
Download:
http://dl.surfright.nl/hmpalert25.exe
Във форума на Wilders Security:
http://www.wilderssecurity.com/showpost.php?p=2309084&postcount=946
AntiRansomware Tool 2.0 Build 9
Програма с чиято помощ ще можете да отключите компютъра си заразен с Ransomware!
What's new in this version:
[*]Fixed issue in ICE Ransomware cleanup
[*]Implement process protect mechanism to prevent the tool from being killed by ransomware.
[*]Note: WinXP x64, Win2003 x64 are not supported by this feature.
[*]Less strict terms/rules to determine whether a file is a malware or not. As long as the file in registry autorun key has no digital signature, it will show suspicious. Because of this feature, the user should fix items on AR Tool carefully.
 Download: Trend Micro AntiRansomware Tool 2.0 Build 9 | 4.3 MB (Freeware)
View: Trend Micro Website
  • 1 месец по-късно...
Avira PC Cleaner - скенер за допълнителна проверка
Засега само на немски език, но се работи и по англоезична версия.
Сваляне
На десктопа се пявяват две икони; бялата е за премахване на скенера след проверката:
OPSWAT Security Score
Обикновен инструмент за диагностика от сертификационния орган на инструменти за защита.
HitmanPro.Alert version 3
Промените
http://www.surfright.nl/en/home/press/surfright-announces-alert-3
Скоро ще пуснат първата бета.
A public beta version will be released after RSA Conference USA 2014.
Промените
Здравей! Дано да са намерили най- после верното решение, че доста се забавиха с разни проблеми - във форума на Wilders Security темата стана над 50 страници. И да допълня, че опцията exploit mitigation  ще е платена:
Quote:Originally Posted by KaptainBug
Eager to know what will be available in free version ?
Everything, except exploit mitigation, which will require a HitmanPro license. If you already have a HitmanPro license, you get this as a free bonus. If you buy a license for Alert, you get HitmanPro for free. One license for all.
http://www.wilderssecurity.com/showthread.php?t=324841&page=51
        Нова версия  на AVZ - 4.43
Вышла новая версия антивирусной утилиты AVZ - 4.43. Архив с утилитой содержит базу вирусов от 23.02.2014 - 297614 сигнатур, 2 нейропрофиля, 56 микропрограмм лечения, 405 микропрограммы эвристики, 9 микропрограмм ИПУ, 236 микропрограммы поиска и устранения проблем, 649446 подписей безопасных файлов. Новая версия содержит ряд доработок и усовершенствований.Основные модификации:[++] Новый функционал - диагностика сети для выявления проблем, создаваемых вредоносными программами (диагностические операции находятся в обновляемой БД)[++] Добавлена эвристика для обнаружения вредоносных заданий планировщика[++] Редактор скриптов - подсветка синтаксиса, всплывающее меню редактора и поддержка типовых горячих клавиш[++] Фильтр в менеджере автозапуска (отображение всех или только неопознанных по БД чистых)[++] Окно редактирования и выполнения скрипта : добавлена подсветка синтаксиса, выделение цветом специфических команд скрипт-языка AVZ, отображение строки и столбца курсора, поддерживаются стандартные клавиатурные сочетания типа Ctrl+A)[+] Вывод MD5 по процессам в HTML отчет[+] Вывод полного названия версии ОС в протокол и XML[+] Доработана стратегия карантина (повышение качества карантина на x64, улучшен парсер)[+] В просмотре карантина добавлено отображения сведений по выделенным файлам (количество и суммарный размер)[+/-] Работа параметра spoollog изменена (если не указан полный путь, то он отсчитывается от каталога AVZ)[+/-] В XML версия файлов выведена в формате x.x.x.x[+/-] В описании задания планировщика в XML выведены все поля (ранее часть была доступна только в HTML логе, новые поля JobName, Status и FullCmd)[+/-] XML: добавлено экранирование символов 0x00 (NUL), такие символы заменяются на пробелы для устранения проблем с парсерами протоколов[-] Исправлена ошибка парсера имени файла в автозапуске и диспетчере процессов (было доступно в 4.41 через обновление баз)[-] XML: Исправлена ошибка с дублирование имени параметра в XML, из за чего лог не проходил верификацию парсеров XML[-] XML: Исправлена ошибка с отсутствием пробелов между параметрами в XML, из за чего лог не проходил верификацию парсеров XML[-] Исправлена ошибка с локализацией MessageDlg (в английской локализации были русские надписи на кнопках)
Download: http://z-oleg.com/secur/avz/download.php
  • 4 седмици по-късно...
Сега пък пуснаха RC на Hitman Pro Alert
HitmanPro.Alert 2.6.3 Release Candidate
Промените
We are preparing the stable release of HitmanPro.Alert with CryptoGuard. This build is the release candidate.
Changelog (compared to version 2.6.2)
  • [*]IMPROVED: Compatibility with Kaspersky, Bitdefender and Norton [*]IMPROVED: CryptoGuard filter driver [*]IMPROVED: Overall
performance [*]FIXED: Lingering Silverlight agcp.exe process
Existing Alert 2.6.x users are automatically updated as we speak.
New users can download Alert 2.6.3 from the link below:
Download
http://dl.surfright.nl/hmpalert26.exe
HitmanPro.Alert 3.0.12 build 63 CTP1
HitmanPro.Alert 3 Community Technology Preview 1 is now available!
With version 3 we deliver comprehensive exploit protections and anti-espionage technologies to both home users and IT professionals. The software works in real-time and does not rely on signatures or the cloud.
NOTE: HitmanPro.Alert 3 CTP1 is pre-release software and should not be used in production environments.
Hardware-Assisted Control-Flow Integrity (CFI)
Alert version 3 introduces hardware-assisted control-flow integrity, which leverages special Intel CPU hardware registers to monitor how software executes on the CPU. This allows Alert 3 to detect sophisticated return-oriented programming (ROP) attacks. Read chapter 2.5 of the Exploit Test Tool manual (provided in the download below) for supported Intel CPUs.
New Features (compared to version 2)
  • [*]Exploit Mitigation [*]Active Vaccination [*]Keystroke Encryption [*]Webcam Notifier [*]Hollow Process blocker [*]Integrates with HitmanPro
Exploit Test Tool
To verify the correct working of HitmanPro.Alert we have developed an Exploit Test Tool. This safe and easy-to-use tool can perform over a dozen exploit techniques that attackers currently use to compromise computers from remote. The Exploit Test Tool can also act like a keylogger and access the webcam. A manual is provided in the download below.
Download
http://test.hitmanpro.com/hmpalert3ctp1.zip
License
Exploit Mitigation requires a valid HitmanPro license. A trial license is available from within the application. The regular HitmanPro paid license will work as well and is available from our online shop.
HitmanPro.Alert 3 is free software if you already own a license for the HitmanPro on-demand anti-malware software.
Users who would like to try the software beyond the trial period can send me a PM for an extended trial key.
Known Issues
  • [*]Malwarebytes Anti-Exploit is currently incompatible with HitmanPro.Alert, but the Exploit Test Tool is compatible. [*]AutoIt applications like AdwCleaner show a warning when started. Temporarily disable Active Vaccination allows the AutoIt application to run. [*]Webcam Notifier works with standard webcams. Webcams using vendor specific drivers are currently not yet supported. [*]Alert counters in the UI are currently disabled but exploit detections are logged in the Windows Event Log. [*]Alert 3 is currently incompatible with Emsisoft Anti-Malware on 64-bit versions of Windows. Workaround: disable exploit mitigation on IE11 and Chrome 64-bit.
Please report issues via PM or email [email protected].
Новите неща, разяснения за ключови функции, проблеми, линк за download:
http://www.wilderssecurity.com/threads/hitmanpro-alert-support-and-discussion-thread.324841/page-71#post-2389909
Virus Scanner - онлайн проверка на файлове
Официален сайт: http://checkfile.ru/
Download:  http://download.checkfile.ru/VirusScannerSetupRU.exe
